Macerator toilet operation
2 Allies
Theda,
Disregard my picture. I just realized you have the Dometic unit ours is the SaniMarin.
But you may find it may be similar.
Sorry for any confusion.
2 Allies
Theda,
I attached the manual below. If you can figure which wire is the signal wire from the black tank, you may be able to disconnect and see if it will function then.
  • 7640 toilet manual_250127_223926.pdf
Theda
Hi thank you for your help we tried to find the sensor lead box we even went under the shelf where wires and vent continues to run I attached pictures of the areas
Any other ideas greatly appreciated
Thank you
brentterry830
Also, Michelle of Alliance Service said in the 395DS, the Control Box is behind the bottom drawer. She sent me a picture of an earlier model which only had two drawers in the rear bathroom. Ours is a 2025 and has three drawers. I asked her which drawer now that there are three, and she replied the bottom drawer. I have not verified this location as my 395DS is at the R&L RV Sales Dealer as my Macerator Control Panel shows "Full" even though the main control panel of the 395DS shows 1/3. I have had it there twice to be corrected. They failed the first time. I do not know if they corrected the issue this time. I plan to drive there in the next few days to verify they have or have not corrected the issue. I knew I needed the wiring schematic and pictures from this forum before I saw A&L face to face. I will have plenty of education and facts so that I am fully educated.
Jdcrabtree3
Were you able to figure this out as our is doing the exact same at this point and I do not know why. Or thst fix for it.
