jagibson58
Would adding one Coleman Mach soft start enable us to use the 12 volt refrig. and one hvac for one or two days ( probably connected to a family members 15 amp outlet) ?
We can run 1 AC from our garage 15 amp outlet and the converter which in addition to your battery takes care of the 12 volt side. No soft start needed.Would adding one Coleman Mach soft start enable us to use the 12 volt refrig. and one hvac for one or two days ( probably connected to a family members 15 amp outlet) ?
My thought on this is simple...most people buy (or have) cheap extension cords, that will lose voltage and heat up over a long run.OC, so I guess we will agree to disagree on the use of the rv 50 amp cord.
I don’t like dragging out the 50 amp cord at home, just to do maintenance or pre cool the refrigerator prior to departure.....
Certainly respect you thoughts, and I can’t disagree. As with everything electrical, proper circuit sizing is extremely important and critical to safety.My thought on this is simple...most people buy (or have) cheap extension cords, that will lose voltage and heat up over a long run.
