I have a 2024 alliance paradigm 380mb. On the living slide the two LED lights are barely on when I flip the switch. I thought they were bad so I replace one of them and it was the same thing. very dim. then aftet 10 min they both turned bright. Is this normal? I checked voltage and it was 12v at the light.
This could be a power or ground issue. Did you check the voltage using the wires that are supplying the lights (power and ground) when things were dim?
You could have a compromised connection as a result of the slide going in and out. Or it could be a bad switch.
It could even be possible that one bad fixture is causing your issue, so have you tried disconnecting each one, one at a time to see if it makes any difference?
This is definitely not normal.
We actually installed dimmer switches on the living slide out lights to reduce their glare. It was just way to bright for our liking.
