Inverter Wire Routing - Delta Trailer
crumjack
We will very likely go with a 252RL as our next camper and I would like to setup a system similar to what we enjoy in our Micro Minnie FLX. There are some awesome threads and expertise in this forum so I was hoping I could get some guidance on a couple of questions.
1. I'm leaning towards running wire for a 50amp inverter setup rather than using the 30amp inverter prep. Can I use the existing inverter prep cables to pull the correct cables thru? Are there other recommended ways to run these cables?
2. Moving batteries inside - It appears there is a bus bar in the pass thru space next to the solar charge controller. I assume I'd disconnect the battery cables that appear to be running to the tongue and run my cables. It looks like these cables would run to a Lynx Distributor or something similar. Should I add a fuse between this connection?
If I'm totally in left field on this, please let me know. I'm having a lot of fun researching and learning about building these systems but still very novice!
252RL comes with 30 amp inverter prep. See photo. I have replaced the conduit box with a power max automatic transfer switch and ran a plug to my existing 1500 amp inverter until I upgrade it. Still need to get lithium battery. I will either put lithium battery in cargo bay or run dedicated cables to battery as larger gauge wire is required for an inverter.IMG_4317.jpeg
