Inverter prep questions
meatball
I have a 2025 alliance delta, 292 RL .It has an inverter prep ready i'm trying to hook up my bluetti ac200l to it, i would like to connect it in the basement where the inverter prep is with a 30 amp female plug. So what is the simplest way to connect it? And can I put a switch to shut off the converter there, too? So that it won't charge the house batteries?
Thank you
John
The simplest method is to just plug in your 292RL shore power cord directly into the TT-30 outlet on the Bluetti (adapter if needed).
meatball
That is the simplest way. But I'm just worried if it rains out, it will get wet and get damage.. I would like to keep it in the basement. And to run that chord from the back all the way to the front is a pain in the ass.
UFF
I just run a small 2k inverter. I just plug it in and turn it on when I am boondocking. Have to charge the battery in am and pm. But I can pick and choose what I want to run. Coffee pot and microwave will suck the power. This is a fifth wheel but same concept. You will have to run the cord but it can be a smaller one. This is just how I did it.
meatball
That looks pretty simple. And that's what I was thinking in my head. Just couldn't get it out. Thanks, i will still have to shut off the converter inside.or can I put a switch near the inverter prep
