Ronpete730
Continuing our maiden voyage of our Paradigm 382RK and no ice in our 12v Furion fridge. Checked the forums and this appears a common issue. A little more study and found the water line with shutoff and plastic ice maker hose not connected under the bottom drawer next to the fridge. Ran the water line into a container to clear the antifreeze from the line and connected it to the ice maker line with the nut and brass compression fitting that was left on water line. We now have ICE! It would have been great if the dealer prep had checked this. I think I understand the reasoning from the factory that ships the rv winterized with antifreeze so that the ice maker wasn’t impacted. Living in Texas where the winters aren’t so harsh, I blow out the water lines instead of using antifreeze (only in p-traps). Know I know how to clear the line to the ice maker.
