For clarity here, are we talking about the GFI outlet tripping OR the breaker for the GFI tripping at the electrical panel?Well, something new today. After I took it out and looked at it last night I found nothing. I put it back in, reset it and it worked just fine until about 15 minutes ago, that was approximately 18 hours. All of a sudden it tripped again! I am fairly good with electrical issues because of my Air Force career, but not sure what is happening here.
When you removed it, where was it at within the over all circuit?The GFI outlet is tripping.
Ok, good to know, placement within the circuit determines which outlet are protected for ground fault issues.It is inline and the bottom wires are the supply side.
Glad to help, please follow back up with root cause! It’s helps all of us sharpen our saw!Thank you and have been able to trace it to 1 outlet or the TV.
So, I will assume your inspections didn’t uncover anything obvious that would be the assignable cause?Update, we have traveled to a brand new RV resort in Idaho and are no longer having the tripping issue. I did check everything with my meter and all seems to be well. Thanks to everyone for trying to assist.
Well, I am glad that you are no longer experiencing the issue, have to wonder if something at the previous park was causing the issue, it would appear so.You are correct, I looked at everything, tested everything that I could and all is good. I noticed when we hooked up at the other park, all of the GFI's tripped. It was a small park and they were doing some work at the park.
