Furnace not heating both zones
JoeLNemeth
The furnace in my Avenue 33RKS only worked in the upper zone last night. Any ideas? It worked fine when the last front came through but we. Brave moved our RV
CornCrib
I say since it did work previously, and doesn't work as well now .... my guess would be a duct run has become loosened or disconnected. Did you take a quick look behind the basement wall and see if the run to the living room came loose? Another way to quickly check would be to completely block off the bed and bath vents and see if the vents in the living area blow harder. If not, something probably came disconnected below. Good luck
JoeLNemeth
Thanks, That's what I figured. I just wondered if it happened to anyone else. We are full time and our first trip was only thirty miles on smooth roads from the dealer to an RV park. Now we are camp hosting for the National forest service and the road in was Bumpy to say the least....
