Furnace issues
Hi. I'm having an issue with my heat furnace. It lights, runs a few minutes and shuts down. Also, my bbq connection won't work. If I connect directly to tank, it's OK. I'm hearing it could be the regulator. I have duel tanks on my valor 36v11. Thoughts?
Have you had all appliances on at same time to bleed all the air? I had issue with water heater until I ran everything simultaneously.
Turfengineer
If your BBQ supply hose has its own regulator, you may need to remove it as your RV already has one. Running LP through two regulators will drop pressure to much.
If you furnace is shutting off after a few seconds I would guess the flame sensor needs cleaned, but it appears to be a few minutes so that’s likely another issue.
Bbq is ok. I didn't know it had a shutoff valve. I think it's my regulator. I ordered a new one. It was showing that a tank was empty, but it was full. I'll try that first.
