I cannot speak to the Paradigm line of rigs as I have an Avenue. On my 32RLS I did discover that there were only 2 lags installed on the door side of the rig - and one of these was walking its way out. In talking with Alliance, at least for my rig, the standard is to have lag bolts in all holes with a minimum of 4 bolts. I went ahead and installed bolts in all holes and had to put a 1/2 bolt in one of the holes as it was stripped out. Even after doing this, I had problems with the bolts working their way out. I removed all the bolts and reinstalled them with starlock washers and this seems to have solved the issue. On the non-door side of the rig, under the bed slide, all of the holes had bolts. Just as a check on the door side of the rig outside I pulled the trim to look under the rig where the pinbox is and it appeared that all of the screws were in place there. I think it is worth checking to see that all of the lags are in place - takes a bit of work but is a good thing to check.
