Folks, just wanted to get the word out. Please beware that the current online owners manual doesn’t contain any special instructions regarding disc brake operation.
Specifically, it is imperative to tow your coach with the truck lights on. While this might be obvious to some, there should be some sort of call out in the owners manual regarding the reason why.
We ordered our 2024 310RL with the disc brake option, it appears this option drives the need for a factory installed DC/DC battery charger to be installed as well. I assume this is to keep the battery optimally charged do to the added draw that the brake actuator pump places on the electrical system.
This charger requires a Ignition Switched Based ”Trigger Wire” to turn it on and in turn charge the battery. It appears that the factory is attaching the trigger wire to the light circuit in the 7 pin junction box on the rear of the pin box. So unless the truck lights are on there would be no battery charging to the coach. (other then the standard solar at least in our case)
The trucks charge line connects to the 7 pin box and in turn to the DC/DC charger inlet(+) .
This DC/DC is also an isolator and will not allow any current to pass thru it unless it is activated by the trigger wire.
I see this missing documentation as a big safety miss, as the battery voltage would be depleted with each brake activation and without charger activation there would be no voltage to charge the battery). Voltage could get low enough to prevent proper brake activation.
Just wanted to get the word out to owners and hope that the A-team will update the owners manual with this critical safety information.
Lights on for safety and charging Allies!
