Dirtbike carrier on rear hitch receiver - Delta 252RL
wvchilling
Hi All,
Not really sure if this is the correct category for this question, so if it isn't please let me know where to post it.
I just bought a 252RL with a rear 2" receiver. I want to put a dirtbike carrier on it, but was told that the max hitch weight is btw 200 and 300 pounds. I can't find where that it is listed in the specs, though.
My question is that has anyone used the receiver to carry something like a 300# dirtbike with carrier? If so, how did it work, or did you have to reinforce it? I want to make sure I am good before I try it and possibly lose my dirtbike while heading to the campground.
Hi All,
Check out page 51 of your owners manual.
Link attached below.
Enjoy your new rig!
Hi All,
I think 300lb is the max your supposed to put on the neck of that hitch.
Reinforcement is a must If you go over 300lb. Also not sure if reinforcing that area affects your frame warranty?
Ox262
I think there's a sticker on the hitch showing the capacity, 300lbs. Given the poor stock suspension on the Deltas, I wouldn't want anything over 150lbs bouncing on the back of the trailer.
I've never seen any mfr state it this way but if you hang 300# on the hitch 24" away from it then you're putting 600 lb/ft on the hitch. To take it to a ridiculous extreme you wouldn't expect it to support 300# on a ten foot long extension. I'm just saying take into account how far away from the hitch the load's center of gravity is.
I worry about my 200# toolbox back there to the point of at least considering adding a cable to it. At least then I'd drag it down the road with me. LOL
Your goal can be achieved, just not with the factory hitch. On our prior RV, I had a custom hitch built and welded to the frame. I also had them built it with 2 inserts, to avoid the rocking from side to side with a single insert. I put ~15k on the RV with this motorcycle (shown is WR250, but I later moved to WR450) and never had an issue. I did keep an eye on the frame for any cracking, but that never happened.
I left the middle insert there, in case I wanted to add a rack in future...but I never once used it.
