Dimmer Switch
JHC
I purchased 2 dimmer 12v switches for the lights above the recliner chairs and dinette. However the current light switch is a 2 wire and the new dimmer switches are a 3 wire. See pics. Suggestions on how to wire or did I buy the wrong switches?
JeffS
If it's like the one I used, the red and white replace the one on the current switch. You have to figure out which one goes to the light. The black needs to go to ground, which is probably part of the wago connector. Use a voltmeter to confirm.
Jeff is certainly on the right track here, search this forum by keyword dimmer switch and you will get several posts.
The three wires are necessary for the dimmer to function.
The switch will have a supply, load and ground wire. I would hope there would be some instructions or a diagram on the switch to indicate which wire is which.
My came with instructions, as he indicated you can use a meter or test light to figure out the coach wires.
Read thru the post that are returned from your search, they will help you.
A second look at you pictures and I see an instruction sheet folded up in the bag in your picture, the ground circuit that your switch would tie into is the 3 splice connection, that leaves the supply and load side to figure out on your switch, give those instructions a read. follow back up if more help is needed.
KCAlis
Installed the same dimmer.
Here’s the thread.
