Delta TPMS prep means what?
Ox262
I recently purchased a 2026 Delta 262RB and want to add the TPMS repeater. I removed the plug in the front compartment and was hoping to see two wires for connecting the repeater. I see lots of wires but none that were "prepped" for wiring a repeater. Are they in there? Or does TPMS prepped mean Alliance just made a hole to run my own wires?
rdrew
I couldn't find any wiring prep on my 292RL either. I caught 12v from one of the bus bars, and the ground on the galvanized electrical box above it. Only had to run about 18" of wire.
Ox262
Thank you for the reply. I removed the wet bay panel hoping to locate the two wires but didn't find them. And I didn't want to poke around too much given the rats nest of wires and plumbing. However, I did find a coax cable not connected, and two other coax lines connected to the wet bay panel. Any idea what the third coax line is for? Thanks.
