Catastrophic fuseable link
jagibson58
Catastrophic fuseable link, an electrical part to protect other components such as the battery from serious injury.
IMHO, there is nothing wrong with adding some additional safety measures.
Ideally, a catastrophic fuse would best located as close to or more ideally on the battery connection. This would ensure all of the main positive cable would be protected against high amperage shorts. I will assume you rated the fuse for the ampacity of the cable it is protecting?
Only needed if you have something like an inverter that pulls high amps.
I might be thinking about this wrong.
But would it also make sense anywhere you have a large unfused positive cable coming off the battery? Thinking protection from any large inrush. I could be wrong.
Without an inverter, the biggest surge you could see is the jacks. That "could" peak to just under 80 amps, but in reality it runs well under 30 amps. These are of course just my thougths, so if someone wants to install a catastrophic fuse for just 12v power needs, then go for it :)
I use one for my setup, but it is for the Inverter draw from battery. See red arrow below
