I would agree with Jim, you likely have some calibration work to do.My battery monitor is flashing zero AH and won’t stop beeping. I’m on 50 amp shore power, everything else works while the inverter is on.
How do I stop it from beeping?
Your very welcome, you will definitely need to perform the AH programming and the calibration process when installing new/different batteries. No sense going thru the motions if you have new batteries on the way(unless of course you what to practice the process.Thanks for the link and information, this looks like it also needs a fresh calibration if you install new batteries. Not knowing if these 3 old batteries were ever serviced or maintained, and they won’t take a charge now. I ordered 3 new batteries from Amazon and I am thinking about performing the calibration after I finish the install. Any thoughts?
