John, no worries at all, just trying to help out an Ally.
I can’t speak for that style Solar control, I was hoping for a LED that had numbers and icons on it to ensure you were set for FLA batteries. You could get on Victron’s website and look up the manual to be sure things at set correct.( it could even be an auto detect model, maybe OC can chime in, he is very knowledgeable on Victron’s equipment.
As far as your breaker and fuse panel goes, it appear that you are equipped with the new style and your converter is actually mounted behind your panel. The new style isn’t equipped with a switch the is easily accessible like the integrated panel on previous build years.
If you can access your converter and determine what color light is lite, that will help identify if the setting is correct or not. If it isn’t, there is a small tool/key that Is inserted to press an internal button to change the battery types.
I attached a graphic below.
