Backup Camera Prewiring
tomkohler
We have a 2024 24RK Alliance Avenue that is prewired for a backup camera and the wiring can be accessed through a rubber plug located near the roof on the back of the camper. I assume the wiring is for a Furrion camera, but there's no information in the owner's manual about the camera so camera compatibility with this wiring cannot be confirmed.
Does anyone know if the wiring is compatible with Furrion cameras?
Thanks in advance for your help.
The "wiring" is just 12v supply. You can use whatever camera system you want. I decided NOT to use the factory 12v supply, as I just knew I would forget and have to come back into the RV to turn it on. I just grabbed 12v power from the market lights and now the camera comes on when I have truck connected to the RV and the headlights are on. As an added bonus, if the 7 pin connector ever comes unplugged I will know quickly, as my camera's will shut down. Here is my install video if you need some more help...
If installing side cameras, be careful that you don't grab the live wire to the blinker. It turns your side camera off when you activate your turn signals. That is if your side marker lights are also turn signals.
Don't ask how I know about that!!
Happy Glamping!!
