Avenue front compartment wall for inverter mounting
MarkRizRV
We have a 2025 Avenue 24rk fifth wheel and want to mount a Renogy 2000 watt inverter on the back wall of the front compartment, is the wall osb or plywood and is it solid enough to mount the inverter directly or should i add a piece of plywood?
Thanks Mark
It is metal (thin) then OSB...back to another sheet of thin metal into the pass-through storage. I would recommend bolt/washer from battery compartment and then washer/nut in pass-through compartment.
