Avenue 37MBR Multiplus Project Complete
chrsbrq
My project is done (well almost). I just finished installing the Victron system here. This system is AWESOME. For those unfamiliar, I can run the entire RV off of the Multiplus inverter (up to 2500W continuous 5500W max). The 50A shore power passes through the Multiplus and to the main breaker. But even better, when I am on 30A (or even 20A) the Multiplus will add additional power from the batteries to compensate for the extra load. So, I can run all 3 AC's on a 30A. It also acts as a UPS battery backup and voltage protection.
Specs: 1300W Solar, 200A / 24V Battery, 2500W Inverter.
Also, I completely ripped out the factory inverter prep wiring, all the way back to the breaker box.
Coming soon I will post a video of the step-by-step installation on my Avenue 37MBR.
1911LVR
Waiting for my 37MBR to arrive! First thing I plan to do is install a dual inverter setup similar to yours.
1911LVR
Very helpful video, thank you very much! So that back board is strong enough to hold? I was thinking about mounting plywood to the back wall to support everything.
