You are correct, If you are installing without an auto transfer switch, hook your inverter wires into these connections. You are going to need different connectors to allow the extra wires for the inverter.
I am installing with an auto transfer switch. If you are going this route you need to wire the transfer switch with feed in and out and the inverter as the alternate feed. I am also installing a 3000W inverter and will be pulling in 10/2 wire (if Alliance didn’t make it impossible?). You must know which wires are line and load to install the transfer switch to work correctly.
