Any issues at higher altitudes, any solutions?
Propane does not inherently lose BTU output at higher elevations, but the lower oxygen availability from "thinner air" requires appliances to be adjusted, often through a process called derating, to maintain safe and efficient combustion. This adjustment typically involves reducing the fuel input rate by about 4% for every 1,000 feet above 2,000 feet elevation to prevent overfiring and potential carbon monoxide issues.
Having said that, I don't know where the adjustment are on the tankless water heater, as we have the tank version.
Socal-Paul
I’ve never made any adjustments for altitude and never had a problem. Do you adjust all your appliances when changing altitude or is it just when it is for an extended period of time?
