Accessing TV Input Jacks on 2026 Delta 292RL
wsiegrist
Does anyone know how to access the input jacks on the TV in a 2026 Delta 292RL? I would like to connect a DVD Player and a Fire Stick so I have options.
As a new owner, trying to figure out where the Wingard satellite TV antenna On/Off switch is located. First campsite had cable TV but I could not tune any cable channels because I could not turn off the Wingard antenna.
Thank you!
Look somewhere for a single gang faceplate with a coax connection and one or two small buttons.
Mine is in the pass through compartment on the passenger side rear wall. The left button turns off the Winegard 360+ WIFI power and right turns off the OTA signal amplifier.
There should also be some unconnected coax cables behind the wetbay panel. Refer to this for more info. https://alliancervowners.com/forum/resources/categories/televisions.28/
Upvote 0
Thank you!
Regarding your Wingard switch, unfortunately it varies by model. For example on our Paradigm it is in the basement on the campsite.
I have heard other models being mounted in the bedroom beside the bed or even inside a closet.
Sorry, I can only send your on a scavenger hunt and wait until someone with that specific model chimes in.
Congratulations on your purchase!
Upvote 0
Dadmck
Good morning,
I have a 2025 Delta 321BH. On my model the inputs are accessed by pulling the TV out - it is on a mount with an arm, which allows me to pull it out from the wall. My TV antenna on/off switch is in the bedroom closet. There is a coaxial plate with small buttons on it.
Have a good day!
Upvote 0
wsiegrist
George, thank you, I appreciate your feedback.
Upvote 0
wsiegrist
Bryan, thank you I appreciate your feedback.
Upvote 0
wsiegrist
Good morning,
Have a good day!
Dadmck, Thank you, I appreciate your feedback.
Upvote 0
Top942002
Side note for future "to do". TV signal (db) is reduced by open coax connections. Little by little it can add up. Purchase some 50 ohm coax terminators and install them on the unused female coax connections. Had this issue on my last unit. Signal improved.
Upvote 0
