Accent Switch on the indoor control panel
We have a new 2024 avenue 26RD, there is a light switch on the control panel inside the door that is labeled "Accent". I cant see any lighting turning on and off when using this switch. When we did the walk through at the dealer, they didn't know what it was for either.
Anyone know?
Thanks in advance
GnR Adventures
Todd F
Accent light switch in our Valor is basically led lighting along the top of the ceiling in the main living area behind a wood trim piece. Can't say that we've ever used it. Kind of forget that it's there.
Went on our first trip this weekend and discovered where the "Accent" lights are located. Under the trailer on the outside. Not sure "Accent" would be the word I would choose, but hey now we know where they are... LOL
Well, nothing like field research to figure things out, hope you had a great time on your first trip!
I am guessing Alliance has this mis wired or maybe the switch is mounted in the wrong spot on the panel.
Our our 310 RL, our Accent lights are interior and mount around ceiling and cabinets as others have posted.
Our underbelly lights are labeled Ground Effect on the panel.
Thanks, we had a great time! Saw one other Alliance on the road. Hi to the east bounder on Hwy 105 in Texas. Also the one of the camp host where we stayed has an Alliance. Great weekend in the woods! Yeah, no switch on ours called "Ground Effect".
rayep
My 2021 Valor 36v11 has accent for interior like mentioned in the ceiling behind the trim and ground effect for under the front half of the RV.
Same set up you described on my 295MK
Jim J
your right thay are labeled wrong effect is outside lights accent is the lights inside top of sealing.
