AC Performance
Socal-Paul
Pulled off the inside covers on the bedroom AC discovered the fiber cold air duct had not been cut off as prescribed, it was folded against the bottom of the cover. I decided to check the living area AC and found the baffle between cold air and return air was not in place hopefully they will both work better now.
Gleninaz
It is over 100 here and my 340rl has three ac units. The two in the main living area were not doing so good and I discovered the return under the bottom step goes out to the bay and hot air was coming in. Had a piece of 5" foam cut to fit tight and they are doing better. Might check that. I will remove it in the fall when I need the furnace.
