Hi, new member with a new 310RL. Just found out that the Bathroom GFCI is inoperative & won't test, the bedroom outlet on same wall is inop, the storage outlet (GFCI protected) below the TV side is inop and bedroom TV has no power. Am I correctly assuming that these outlets are on the same circuit and the probable cause is a bad GFCI outlet in the bathroom? What is also interesting is that on pre delivery inspection, it was discovered that the GFCI outlet on the kitchen island was bad and the dealer replaced it. So I sense a trend. Any insights or helpful thoughts appreciated.
Thanks much!
Congratulation’s and welcome to the forum.
I wish I could be more definitive and tell you exactly what outlets are tied together but I can’t. Honestly , I am not sure any two units are even wired alike 🤣.
If you haven’t already, I would offer the following.
1. Check your main breaker panel to see if any breakers have tripped.
2. Check for any other GFI’s that might be tripped. Perhaps the outside outlet on the Dinning room slide or maybe above the Nautilus Panel
3. Maybe one in the basement storage on the back wall.
It would be odd to have numerous GFI’s go bad in the same rig so quickly.
I would be checking for loose connections thru out the rig, starting at the 50 amp shore power connection, the breaker panel and each outlet. Basically, if you see a connection check it to be sure it is tight.
This small investment in time, will pay dividends down the road in reliability
Sorry your having issue with your new rig. Please keep us posted on what you find.
