Oldfireguy
Hello Allies, my basement LED lighting on our 2025 385 FL is on night and day while at the RV park. I can’t find any switch to control that circuit. Any ideas?
So these normally don’t have a master switch at a control panel.Hello Allies, my basement LED lighting on our 2025 385 FL is on night and day while at the RV park. I can’t find any switch to control that circuit. Any ideas?
Good info Sir. It looks like mine are hard wired. Looks like I will install some switches soon. I attached a pic on current factory install.So these normally don’t have a master switch at a control panel.
On ours, each light has a rocker switch on it. I can’t remember if it is 2 position or 3 .
But none the less, one position would be constant on, one would be motion activated and if it has the 3rd, it would be off. Inspect each basement light for a small rocker switch that is part of the fixture.
Thank you. They might have been in a hurry right before Halloween. Ours was put together in OctoberSend an email to service@alliancerv.com and let them know your issue, put the last six digits of your serial number, they will help you resolve. Our '24 385fl is on a motion sensor and are working great. Have not had an issue to have to look for a switch.
Good luck,
So these normally don’t have a master switch at a control panel.Good info Sir. It looks like mine are hard wired. Looks like I will install some switches soon. I attached a pic on current factory install.
