2022 Paradigm 310rl
fdr
Does anyone know the exact location of the black tank vent line in basement and the exit point on the roof? Having issues with sewer gas when dumping black tank. Didn't want to do the sniff test on all roof vents..Any info would be greatly appreciated . I do know that I have 3 pipes through the roof with the black one closest to driver side being an open pipe chase.
As you might expect vent pipes will be directly above their corresponding tanks. Look behind the panels in your pass through and take note of the larger of the two black ABS pipes — that’ll be your toilet pipe. All the tanks in the diagram are labeled gray but one of the two side-by-side tanks is in fact a black tank.
You’re correct that on the roof the back “vent” is a wire chase.
Upvote 0
