Toby and Michelle
Can the a/c be run from the battery while the solar recharges it?
Hi folks, the a/c system runs off of 120 volts ac current. The only way you could run the a/c from the battery would be thru an inverter system.Can the a/c be run from the battery while the solar recharges it?
It was my understanding that the a/c in my trailer are now 12 volt dc now instead of 110 volt a/c as in the past.Air con only works off AC power. You need at min a 2000w inverter
I believe you are confused or have been mislead. The refrigerators in many units have switched to 12 volt operationIt was my understanding that the a/c in my trailer are now 12 volt dc now instead of 110 volt a/c as in the past.
Can’t do it unless hooked to shore power.It was my understanding that the a/c in my trailer are now 12 volt dc now instead of 110 volt a/c as in the past.
