Winegard DIRECTV TRAV'LER PRO
Rod Emenaker
Anyone install a Winegard DIRECTV TRAV'LER PRO on a PARADIGM 340R
Looking for ideas for best location on roof, inside box and where to run wires.
Thanks
Rod Emenaker
Update
Mounted the Winegard DIRECTV TRAV'LER behind the middle AC and ran wires to the wire chase in the roof.
Installed the satellite box in the storage compartment and used the pre wired coax cables to TV's.
Replaced the living room TV mount with a swing out TV mount and added 4 box electrical plugs.
HelotesAg
Nice job! I've thought about trying installing one of those Winegards myself... big investment though. I have a dish on a tripod that I can usually get going within a few minutes, so not sure if it's worth the $2300 or $2400 to do yet.
On a different note - did you reinforce that swivel arm behind the column? My TV mount that came with it was just screwed into that plywood with 4 screws and - not surprisingly - started coming loose. I added a few more screws to it until after the holidays when I plan to try to open up that pedestal and add some more structure to attach the TV mount to.
