Where are the Solar Prep wires for the solar panels in a 390MP
MartySchwartz
Hi all
I saw the other thread about the location of the wires from the roof on a 310 but I can not, for the life of me, find them on my 390MP. Has anyone looked for and found them? I am about to install solar panels and want to use the pre-wired connections but need to find those blasted wires. Only place I have not looked is the under-belly. I was really hoping I would not need to go there again but it seems that is next.
Any help would be much appreciated.
Marty...............................
Marty - I'll ask someone much more in the know than me and circle back here with that answer.
MartySchwartz
Hi Jim
I would much appreciate that. I have not had any luck finding them and am installing solar panels in the next few days.
Hi Marty,
I connected with Jim Bonacci and learned the follow as to where on Paradigm product, the roof-mounted solar prep wiring terminates inside the coach.
Below, I'll paraphrase what I have learned.
In all cases on a Paradigm, the wires will terminate in the front compartment (front generator bay), typically through a hole in the bottom, ODS corner of this compartment. What these wire ends look like have evolved over time. All the Paradigms should have a red or orange PV+ and and Black PV- wire.
Typically there are MANY other DC wires/cables and hydraulic/hoses entering/exiting the front compartment. The wires from the solar prep will be either 10ga or 8ga depending on when the unit was produced.
If it's an earlier unit then it will be 10ga and a rectangular, red, in-line fuse holder should be present there as well and the wire ends in pre-crimped ring terminals.
If it's a more recent unit, there will simply be raw wire ends with no connectors present, again either in 8ga or 10ga red or orange(+) and black(-) wires.
NOTE: There was a short period of time when Plant 2 produced Paradigms were getting their PV+ and PV- hooked to the aux post of one of the mini breakers and the negative cable to chassis ground.
MartySchwartz
Hi Marty,
Thanks Jim
To this point I have seen nothing like you describe so I am guessing it will be in the belly somewhere. Guess I have to go in there to find them. As to the early or late model I don't have any idea what that means. My unit was built in the first week of May 2021.
Thanks Jim
Marty - here's how I would do this...
Find all the red/orange and black electric wires passing in/out of the gen bay through that round hole. Trace each red wire from the hole to where it terminates in that bay. Make a written note or drawing of this. Through this process, it may become evident as to which wires are for the solar.
Some of the wires may go to the mini-breakers. Some may go to a stud connector. Some may be loose. Try to identify where each positive wire goes and what it's for.
Don't worry about the super heavy gauge positive wires for this exercise as that's not what you're looking for.
Note: I went through this same process, though I wasn't trying to figure out which were for solar. Anywhere I have ?? are lines I have not spent anytime trying to determine what they're for. That will happen next week. My coach was produced in May 2021.
MartySchwartz
Thanks Jim
Yea, I already did that. The only unterminated wire I found in that bundle is a 12-2 duplex wire with a grey jacket. Pretty sure that is NOT the solar wire (certainly hope not anyway). I will have to open up the belly to see where that solar prep wire is and get it routed to the appropriate spot.
Thanks
MartySchwartz
Well, just spent the last hour or so dropping the belly and there is no sign of any kind of wiring that might be coming from those solar panel connectors on the roof. So either I am blind, those wires are very carefully hidden or they are not there. Unless someone has some other idea of where to look it seems I have to run new wires to install these solar panels.
Hi Marty,
Some suggestions...
1. Look at the wire color and gauge of the solar prep, on the roof behind the MC4 connectors. Use that as your guide as to the wires you're looking for in the gen bay.
2. Check for DC voltage on the wires at the prep on the roof. If 12+vdc is detected, then the wires are connected in the gen bay. Start dropping positive wires until you love 12+vdc up top.
3. Similar to 2 above, if no 12+vdc is present up top, consider adding a tone to the wires with a toner, then locating those wires in the gen bay with the toner receiver.
Examples:
- https://www.lowes.com/pd/Jonard-Tools-TETP-800-Cable-Tester-Tone-and-Probe-Kit/5013064439
- https://www.amazon.com/s?k=wire+toner&crid=2WDU7JSLQD010&sprefix=wire+tone,aps,111&ref=nb_sb_noss_1
A toner is a handy tool to have. If you never trace phone, network or coax cables, consider getting the lowest cost unit that has clips for attaching to wires.
MartySchwartz
Well, the mystery has been solved. Solar_Prep.png They never installed the solar prep wiring, just the connector. Someone needs a little more training I think. Luckily I was able to run the PV wires down through the wire way provided next to the tank vents. Since my batteries will be in that area I am actually better off. Still aggravating to find out something that was supposed to be there never was.
MartySchwartz
Another "Hassle Free Upgrade" that is not hassle free. I expected better from Alliance.
In most cases I think they do better, someone on the line had a bad day or missed a step (QA certainly missed it) and I was the lucky recipient of the present. I was able to work around their mistake but I did not enjoy wasting hours of my time trying to find something that was never installed.
MartySchwartz
@MartySchwartz - Sorry to see this. My sense is that this was a production miss. Let us know if there’s some way we can support you on this.
Yea, it was clearly a miss and QA did not catch it.... Don't know if they even check for that. Not much you can do at this point. I am moving the battery bank to inside the conditioned space and the plenum from the roof is directly above where the batteries are going to live so that works out better than trying to use the Pre-wired solar where it was supposed to be. I think I can just cover the hole in the roof from the PV connector with Eternabond tape and call it good.
Marty - your plan sounds solid. Clean the area well and if needed, fill the hole in before applying the Eternabond. Once applied, if you have a small roller, roll over the Eternabond to promote good adhesion. Then use some Dicor lap sealant around the edge of the Eternabond. Not required but if you have some, I'd do it.
