AjaxTreehouse
We have a 2022 40V13 with the DC fridge, and can't find the fuse/breaker for it. Ended up turing off 12V for the whole rig to kill (reset) the fridge.
Jim: I'd be interested in the type of switch you used.Sorry that I don't have the answer for you here, but consider giving our office a call at 574) 226-0140 and ask for the Avenue team. They'll know.
That said, on my last coach (another brand), I added a switch to the DC feed between the fuse and the refer itself. This allowed me to isolate only the refer while leaving DC on to the rest of the coach.
The issue I saw by using the fuse removal method of cutting power to the refer, was when reinstalling that fuse, there's a large current rush that creates a nice spark and I didn't like that. At times, I'd blow the fuse doing that as well. Here again, this wasn't an Alliance product but the same could hold true.
Im having the same problem with my 40v13 fridge do you know where the master 12 volt cut off is?We have a 2022 40V13 with the DC fridge, and can't find the fuse/breaker for it. Ended up turing off 12V for the whole rig to kill (reset) the fridge.
It's in the battery compartment on our rig.Im having the same problem with my 40v13 fridge do you know where the master 12 volt cut off is?
Are you resetting the fridge because it stops cooling? Or do you just want to turn it off when you are not camping?We have a 2022 40V13 with the DC fridge, and can't find the fuse/breaker for it. Ended up turing off 12V for the whole rig to kill (reset) the fridge.
Is there an issue with just letting the fridge run even when you are not camping?Sorry that I don't have the answer for you here, but consider giving our office a call at 574) 226-0140 and ask for the Avenue team. They'll know.
Not sure if you received an answer. We have the Norcold 12VDC 20CF refrigerator in our 2023 310rl….it has 2 fuses (one for the freezer and one for the frig) located at the bottom front in fuse holders. The Load wires (ours is 10 gauge) run direct to the buss bar in battery/gen bay. Safe travels!We have a 2022 40V13 with the DC fridge, and can't find the fuse/breaker for it. Ended up turing off 12V for the whole rig to kill (reset) the fridge.
