Height
Ocheske
So the listed height for our 32RLS Ave is 12’ 10” does this include to the top of the front a/c or from ground to roof only?
mrcomer
Typically the height listed is over the top of your A/C. It would be a good idea though to check it yourself just to make sure.
Whitewolf
I've found the best way to check the actual height is to hook your 32 up to your truck, jacks up like you're ready to roll. Lay a 2x4 on edge or something long and straight across the front A/C extending over the side of the 32. Have someone with a tape measure from the 2x4 to the ground. It's easier for them to grab the top edge of the 2x4 with the tape and then you subtract 3 1/2" from the total. Or if you're like me you don't subtract and use that as a cushion.
