Fresh water capacity
HarveyTheRV
We have a 2021 310RL. I have used a calibrated water flow meter twice and can only get 84 gallons in the tank before it starts coming out of the overflow. Any idea why it won’t hold the 98 gallons that are advertised? I was told that the 12 gallon in the hot water was not included in the 98 gallons.
Whitewolf
That's a very good question. Do you know anyone else that has a flow meter that you can check against yours?
HarveyTheRV
Yes, a fellow rv’er had a water flow meter and it was the same thing. Well .2 gallons difference. We also used both meters to fill a 5 gallon bucket. Both were right on the money.
Alliance if your listening can you advise?
Todd80
Any RV I've owned the stated fresh water capacity DOES include the water heater capacity. Whether the fresh water tank is filled to the top or not is going to depend on the location of the fill tube inlet and vent hose on the tank.
Bill Martin
VP, Customer Experience
Good morning. The tank is classified as a 98 gallon fresh water tank by the mfg of it. With that said the tank is not fully rigid so can have some sag or low spots in it. Also there is no way we are aware of to ensure that a tank of this size is completely empty, even after opening the fresh water dump valve. It is very likely that there are still several gallons of water sitting in a corner or low spot in the tank.
