Fireplace removal/install
How do I remove and reinstall the fireplace, need to access the speakers/wiring? I want to replace the entire sound system.
@david396
  • Open the drawer fully
  • Look on each side of the drawer for screws that fix the metal frame to the drawer - remove the screws (maybe 3 per side)
  • Lift drawer up and off the slide mechanism
After your project is complete and while the drawer remains out, take the opportunity to remove debris and vacuum that space. Then use some dry lubricant on the mechanism before reinstalling the drawer. I found that really helps is slide easy and without grinding.
david396
@david396
Thank you sir, much appreciated!
