I did a bit of a modification in the Paradigm 340RL today. I generally work from my easy chair vs the kitchen table when using the laptop or iPad and I often have lunch at the same chair. In my last coach, I have theater seating that had swivel trays. They were super handy. As my Paradigm seating doesn't have that feature, I added it, but not to the chair - rather, to the slide facia.
The product I used is from Lagun. The Lagun Table Leg System. This system is designed to be used to support a table, up to 30" x 40" and up to 50 pounds. I'm likely not the first to use such a small table top, but mine sure is small. In fact, it's a small wood-composite cutting board.
This is sort of my "proof-of-concept" setup. If it works well, I may make adjustments, like a larger top and maybe some modification to the way I've mounted the bracket to the facia.
