Alliance Team,
A couple suggestions for improvements in future models. We have a 2023 382RK, although there are likely similar improvements to be made in other models.
- consistency in light switch placement. Going up to the bedroom the light switch is on the right. As I go through the door into the bathroom, the light switch is on the left and completely out of place, especially since you have to open the door most of the way to reach it. Placing it on the right side would make much more sense and, if it cost $10 more in supplies to put it there, charge an extra $20 if you want, worth it for your customers. It would be nice to also have it on the right side in the walk-in closet, although in that location there might not be enough space.
- light switch placement in the bedroom. When you're going up the stairs toward the bedroom, when you reach around the wall the light switch is too high (and I'm 6' 1"), since one naturally tries to turn on the light first before blindly walking into the room. Find a happy medium between it being to low when using it from the bedroom side and too high when using it while on the steps to go up into the bedroom.
Thanks!
Brian
Thanks!
Brian
