WoodcarvingGypsy
I've noticed that there may be a parasitic drain on the batteries when the DC switch is turned off. Has anyone seen anything like this or is there something hooked in before the switch? I don't have the camper setting where it can be plugged in at the moment so I'm a bit concerned that the batteries will drain.
At some point, I will put a second disconnect in the line between the battery and the first buss bar. I'mn also going to put in a Thornwave monitor as well.
Observations and suggestions appreciated.
