The other ground lead from the load side of the Renogy shunt looks like it goes through that bulkhead wall and into the underbelly area. My guess is that this is coming from the fuse panel.The solar upgrade and inverter install is starting to take shape and I now have a question. I will be switching from the Renogy shunt to the Victron Smartshunt. There are two negative wires on the load side, one goes to the metal wall for a frame ground and I am not sure what the other does. Any idea what it is for and if it should be wired differently with the new shunt?
Hi @TJJ - disconnecting the charge line for the 7-wire is good advice. I did this at the junction box at the back of the pinbox.I am planning a similar install on our 32rls less the solar for now. I am also adding the victron Orion DC to DC alternator charging.My diagram from the explorist site states to remove the existing charge wire coming from the 7 pin trailer connector as I will run new wiring from the tow vehicle battery to to the trailer via Anderson connectors.Where would this wire be in the converter?
You might consider the Renogy DC - DC for this duty. It is one of the few things that seems to be superior to the Victron products.I am planning a similar install on our 32rls less the solar for now. I am also adding the victron Orion DC to DC alternator charging.My diagram from the explorist site states to remove the existing charge wire coming from the 7 pin trailer connector as I will run new wiring from the tow vehicle battery to to the trailer via Anderson connectors.Where would this wire be in the converter?
For disconnecting the charge line for 7-wire, are you referring to pin #4 Battery Power connection?Hi @TJJ - disconnecting the charge line for the 7-wire is good advice. I did this at the junction box at the back of the pinbox.
Focker,just curious.How many solar watts are you adding?Please post your progress as I’m undertaking this project as well.ThanksThe solar upgrade and inverter install is starting to take shape and I now have a question. I will be switching from the Renogy shunt to the Victron Smartshunt. There are two negative wires on the load side, one goes to the metal wall for a frame ground and I am not sure what the other does. Any idea what it is for and if it should be wired differently with the new shunt?
See the Valor image in the PDF on this resource page: https://alliancerv.com/academy/owne...7-wire-plug-junction-box-wiring-diagram-and-0For disconnecting the charge line for 7-wire, are you referring to pin #4 Battery Power connection?
I have the basic solar from the factory (2 320 watt panels) and I am adding two additional 320 watt panels. I am also adding additional batteries for a total of 4.Focker,just curious.How many solar watts are you adding?Please post your progress as I’m undertaking this project as well.Thanks
Hi Jim, I’m putting a multi plus llI just switched the breaker off for the converter. If you wanted to go a step further, you could remove the red wire from it at the bottom of the fuse panel. I believe there are 2 there so take care to remove the one coming from the converter board and not the one that leads out to the battery as you still need to get DC power from the battery and the new system, back into the fuse panel.
Where do you plan to install your batteries and your MultiPlus-II?
Anytime after 8 am, any day.When is a good time to call?
