New 310rl and heater doesn’t work. Propane on, good fuse but blower does not start when after setting thermostat
Marc-Have you taken off the outside panel and checked to see if the on/off service button is "on"? This may be the issue as it certainly sounds like a power problem.New 310rl and heater doesn’t work. Propane on, good fuse but blower does not start when after setting thermostat
Yes it is onMarc-Have you taken off the outside panel and checked to see if the on/off service button is "on"? This may be the issue as it certainly sounds like a power problem.
Not yet. Tony has suggested a couple things to check. Is there electrical schematic available?Marc-Did you resolve your furnace issue?
With thermostat set to heat, both red and white wire showing 12 voltsView attachment 160You’re not going to get any power at the on/off switch unless the blower starts to run.
Let’s make sure that the thermostat wires are secure and you’re getting power there. Take the thermostat off the wall by tapping it up and pull it out until you can see the wires. Check the wires to see if they are secure and making good contact. See the attached pic. You’ll have 12v or higher depending on the state of charge at the red wire and when you call for heat there will be 12v power to the white wire as well. If the thermostat is wired good and you have good power, then the next step would be getting behind the wall in the cargo compartment to check those wires that are to right to pull out and the wires on the limit switch on the back of the unit.
Would you know where white wire from t stat connects to blue wire going to furnace? Checked in middle ac unit and it connects to another wire in a 2 wire bundle and goes back into ceiling Have voltage at that connection but not blue wire going to furnace when t stat is in heat modeIf you have power to the furnace and the wiring is good, then like I said earlier it is likely a board or possibly the limit switch that is open or has a wire that's not secure. If you let the team know at service@alliancerv.com / 574-226-0140 they will ensure that you get taken care of. Happy Thanksgiving!
