We were excited to receive our new 310RL yesterday and we got the main walkthrough about a month ago and the coach needed to stay at the dealership for installation of slide toppers. We did not get thoroughly checked out on the hookups. We have the new Curt Helix coil spring pin box which is tipped down. We have had for 9 years a GD Reflection so we are somewhat experienced 5th wheelers. At the dealerships things started off badly because the battery was run down -almost dead because they had left some lights on. The service people tried to hook us up but the manual adjustment of the landing gear was sporadic because of the battery power - even though they hooked it up to shore power. I was inside the truck so I did not see how they lined it up but the 5th wheel hitch would not catch and the service person I believed had the pin box too high. He had us push backward with the truck several times to see if it would catch but what ended up happening was that one of the front jacks rod became bent because it was fully extended out, and the weight of the trailer obviously bent the shaft.
They acknowledge that they should have had the Experienced personnel come out and help us, but we were following the directions of the service people. I have since read up on what is the proper alignment. But it seems that hooking up this type of pin box is somewhat tricky and you don't wanna do things to push the coach backwards especially with these skinny little Jacks. Our reflection had the nice square angle iron type front jacks you see on older5th wheels. Have had problems with bent front jacks? (We know that proper procedure is to have blocks under the front jacks so that the posts aren't extended so far and the wheels should be blocked. But I don't see hardly anybody doing that). TIA for any advise.
