I have 3 ACs in my valor toy hauler, plugged into 50amp shore power but cannot get the garage AC to blow any cold air, blows air but not ac cold air, any suggestions? My dealer told me there is nothing wrong with the ac unit, but the air is just not cold like the other 2 are blowing out. We are in eastern washington, it's mid 90s, parked in shade but still cannot get garage to to a comfortable temperature.
Hi folks, I just copied and pasted a few things from one of my previous posts.
Is this a new problem? Was it working previously?
Was any recent work done that would affect the operation?
Do the thermostats light up and display a number?
Are they set to cool mode?
Is the set temperature below the room temp.?
Are the fans on?
Are the direct drop Luvers open?
Are the inlet air filters clean?
Have you checked the freeze sensor, for proper installation and placement?
Have you checked to see if they are icing up?
Have you checked the plenum divider behind the vent covers to ensure it is in place properly to divide inbound and out bound air?
Do you have a way to monitor you coach total amp draw? If compressors are running on all three units you should be in the area of +-30 amps on the system assuming nothing else on the 120v side is operating.
Have you checked for tree strike damage on the roof.
You may have already ruled some of this out, just trying to give you a few things to check.
