If you are direct dumping into the bedroom and reflective measures are in place everywhere, my money would be on the temperature delta. I would hate to think someone didn’t install the insulation, but I guess anything is possible.
We recently returned from a 3 night local trip with temperatures near 100 degrees and heat index’s even higher.
Our 310 RL had no issues keep the coach at a comfortable 74 degrees. We have no reflective measures in place other than the day and night shades, day’s are usually down regardless, and the nights are alway down in the bedroom.
We did order it with dual pane windows, so I am sure that is helping some.(how much is a debatable topic)
Is your temperature issue only in the bedroom? Is the rest of the coach cooling ok?
Have you checked your A/c inlet filters to be sure they are clean to allow maximum air flow into the unit?
Given the numbers you are reporting, something is definitely wrong, what is the question.
Your unit could be freezing up .
Keep us posted as you investigate further.
