This weekend, I installed a 6-pack of RV SnapPads on the Paradigm 340RL. I’ve used SnapPads on my RVs since the product first came out. Love it!
Source: www.rvsnappad.com
I got a set of these to install on our camper when we get it. I wanted to avoid carrying wooden or plastic blocks to use as platforms for the feet. There is enough flexibility in these to (hopefully) protect the feet from getting bent on uneven or soft ground, or getting dinged up by gravel.What is the benefit of these snap pads?
Does anyone know the size of the pad needed for the 310RL ? Thanks
Can someone explain the process of installing or attaching the snap pads?
Thanks
Ground control to Major Tom.... sorry, had to do it.LevelUp and Ground Control, both by LCI, use the 9” jack feet. That said, this is a link to the RV SnapPads you would need:
SnapPad XTRA Product Collection | RV SnapPad®
Level up your RV experience with the best jack pads for your Fifth Wheel or Class A Motorhome. SnapPad XTRAs are custom engineered to fit the standard 9-inch round jack feet on leveling systems.rvsnappad.com
Do you have 6 of these stabilizers, or do you just use them in the front? Thank you for sharing this.I have 6 on my 36V11. The jacks do not slide and offer the wider foot as stated above. I put a little baby oil around the lip the first snap on to ease sliding into the pad. Great for various surfaces to reduce metal jack foot chances of bending.
I like using theSnap Pads with the CAMCO blocks (Camco Yellow Stabilizer Jack Support - Offers 7" of Lift, 5000 pounds - (44424)) to keep the metal feet from sliding. The less you extend your jacks the more stable it feels when you're parking on a downhill slope. I park in fields a lot for races, sometimes I use a large rubber block (Camping World: Hosspad Jack and Leveling Pads - Mega) under these also if the ground is soft or gravel. These are stackable and the center reaches all the way to the ground which should provide more support (in theory) than the red buckets which some reported break in gravel. These blocks still stack nicely and are light.
