I checked those out and looks like a fantastic fix but seems to be a little on the expensive side. So do you feel it was well worth the expense? Did you take it to the factory location to get it installed?We got the Moryde Independant Suspension (IS) on our 2022 340RL. We can tell a difference in towing. The trailer does not "Bottom out" now like it did before the IS while towing on rough highways (Interstate). Tire wear is very even.
I have a couple of questions on the Sumo springs. 1. Did you have the 5.3" to 6.55" clearance between the spring plate and the frame that the manufacturer lists? Our 37V13 only has about 4.75". 2. Did you get the springs installed? If you did, what's your opinion of the springs?I ordered Sumo Springs base on a video from the Wayward Waggs.
I haven't installed them yet on our 340RL, but I will at one of our first stops heading south in January.
I've got them and they are working well. After install, you want them to be compressed at least 1/2" .. Per SS ... so you should be in good shape.We got our 32RLS in July 2023 and have not put too many road miles on it yet since we park it at a lake for the summer. We will be travelling from BC to Yuma in Jan and I am considering the install of the black ones as well. Like Mike Ki above I have questions regarding the gap between spring plate and frame not being 5.33”. Ours is only about 4.5”.
Has anyone on the site installed them on a 32RLS and can you report on the success.
Ya .. that is interesting. I'm got mine installed with a single spacer. I used the jacks to increase the separation, but had no problem getting them in. I did have to move my propane line on the drivers side, but everything needed was included in the kit. (the below pic does not show the spacer installed. I added later per the advice of SS, once they saw these pics).Well, that makes it interesting, I was on the chat line with them this morning and was told they would not work. If I trimmed the Coroplast off at contact area as someone else(maybe you?) I would then have a gap of about 4 3/4”. The difference is then about 1/2” too small of a gap.
According to the person I was chatting with, their engineer said too small of a gap could compromise the ride and make it more bouncy or harsh. That kind of makes sense. Maybe I will call them and talk to an actual person.
I appreciate your experience and input and will reread the thread as well
Thanks
Dale
