mountainmike11
Any suggestions on accessing this or rerouting this last vent pipe? this is the one that goes to the bunkroom clear on the other side of the camper. I talked to service and said yeah it probably needs to be fixed. I tried to get to the clamp to undo it from the closet/drawer access, but is this something to pull the furnace out for? I also highly recommend if you can check your furnace to have it foil duct taped. I recently did this and it makes a huge difference on the amount of air flow you get in your living spaces versus loss in the closets.
