Located in Akron, Ohio
$80,000 includes warranties and all FREE bonus items
Contact Stephanie at stephaniemarie270@gmail.com
*****FULLY TRANSFERABLE WARRANTIES!!!!*****
*Just under 5 years worth of Extended Platinum Warranty, and Tire and Wheel Warranty.
*Just under 4 years worth of Exterior Ceramic Coating Warranty and Interior Upholstery Coating Warranty.
****FREE BONUS ITEMS****
*5th wheel tripod stabilizer
*Clearsource Ultra Three Canister RV Water Filter System
*On The Go Portable Double Standard Water Softener & Conditioner
*Camco Rhino Portable Waste Holding Tank - 28 gallon
*Complete Wineguard WIFI router and tv channel extender kit
*Even a slightly defective but NEW replacement Kitchen Range
...AND MANY MORE!!!
*Purchased UPGRADES/Add-ons*:
*3 Seasons Patio Door - Glass Doors
*King Bed Suite
*Ramp Door Patio Package w/ Step
*Solar Package Plus: 1 additional 320 watt Solar panel (total of 3 - 320 watt solar panels for total of 960 watts of solar), 2 additional 100AM lithium-iron phosphate batteries from Renogy (total of 3), Upgraded 60 amp MPPT solar charge controller from Renogy, 3000 watt inverter wired to approx 90% of 110v plugs in unit and wired to main A/C in living room)
*Splendide Combo W/D Vented WDV2200XCD- Professionally Installed by Dealer
MANUFACTURER FEATURES:
*Independence Package* :
3 A/C's, 42,000 BTU Furnace, Freestanding Range w/ 12,000 BTU Burner and 3.0 cu. ft. Oven, Fireplace w/5,100 BTU Space Heater, walk on Roof w/Seamless PVC Roof Covering, Flush Floor Kitchen Slide, Large
Residential Shower, Commercial Grade Vinyl Flooring (No Carpet), Soft Close Cabinet Doors w/ Magnetic Catch, Hidden Hinges, Soft Close Toilet, Light Dimming Switches, Roller Shades Throughout, HD Smart TV in Living, Residential LED Recessed Ceiling Lights, LED Back-Lit Crown Molding in Living Area, Hardwood Cabinet Doors
& Drawers, Black Cabinetry Hardware, Centralized Docking Station, No In-Floor Heat Vents (Main Floor), Mylar Reinforced Exterior Seals, Sofa w/ Power Recliners, King Serta Mattress, Painted Fiberglass Front Cap, Epoxy Poured Kitchen Countertops, and Azdel backed Fiberglass sidewalls
*Performance Running Gear Package* :
4k Springs, MorRyde HD Shackles & Wet Bolt Kit, G-Range 4400LB Rated Tires w/ 16" Aluminum Wheels, 101"
Wide-Body Benchmark Chassis Platform w/ Flush Floor Upper Deck, MorRyde CRE3000 Suspension System, 6-
Point Hydraulic Leveling, 7000LB Dexter Axles, Rota-Flex Pin Box, Solid Step Quad Entry Steps, Space Enhancing Drop Frame Storage Compartment
*Garage Management System* :
Fully Weather Resistant Ramp Door, Multipoint Tie Down System, HappiJac Rollover Sofas w/ table, Air Compressor, Fully insulated Garage Floor, and Electronic heat source
*Masters of 12-Volt Package* :
17cf 12 Volt Refrigerator, 12 Volt JBL Sound System, USB Charging Stations Throughout, 12 Volt Heat Pads for Tanks, 12 Volt Power Recliners, and 12 Volt Bedroom and Garage TV's
*OTG - Off the Grid Pack* :
2- 320 Watt Solar Panels, 40 Amp Charge Controller, 100 Amp Hour Lithium Iron Phosphate Battery, Battery Monitor System, Auto Generator Start, and Generator Prep.
...AND MANY MORE!!!
*King Bed Suite
